Discussion topic: where is CNN on Sky Go ???
Message posted on 24 Jun 2023 03:35 PM
does anyone know what is going on missng CNN news of the pc and ipad Sky Go? A message was sent to sky.ie and no reply has come yet
Message posted on 25 Jun 2023 05:44 PM
Re: where is CNN on Sky Go ???
@mar181602 is thisat home connected to you box or away from home
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 25 Jun 2023 05:45 PM
Hi,
This is happening at the place the sky box is.
Message posted on 25 Jun 2023 05:49 PM
@mar181602 wrote:
Hi,
@mar181602 what Sky box do you have ? Sky Q or a Sky +HD box If Sky Q do you have multiscreen ?
What is going in as it seems BBC and CNN may be having problems with Sky Q boxes?
Message posted on 25 Jun 2023 05:51 PM
I have a sky box Q with only a single view.
Message posted on 25 Jun 2023 06:07 PM - last edited: 25 Jun 2023 06:08 PM
@mar181602 right i am fairly certain that without multiroom then Sky go will not connect to your Q box so will not pick up all the channels.
Some channels the main one BBC and on checking looks like CNN(i checked on my phone by disconnecting from my home network and changing to the O2 network) is another one that you cannot watch on Sky go unless Sky go is connected to your Q box this is done by the channel owners to make you use their app so I am guess that if you look then the BBC channels will also be missing although you can record these channels from Sky go by changing from watch on phone to record to Sky box
This is not a Sky decision it is purely down to the channel owners not allowing it to happen
Message posted on 25 Jun 2023 06:10 PM
Thank you for your reply.
I'll pass it on to the person here who will check this out.
The sky signal here does go around the entire place.
