9
Discussion topic: how do I block someone from using my skygo
This message was authored by loucamp80 This message was authored by: loucamp80
I let my kids dad's cousin use my skygo and said she can use it over Xmas and then I said she can use it till end of January and I've messaged her and told her she needs to stop using it as her times up she said she isn't using it which is a lie cos her and her bloke are the only ones using a PlayStation to watch it can I block them from using skygo
This message was authored by caesarome This message was authored by: caesarome Answer
Re: how do I block someone from using my skygo
@loucamp80
Try this:
First change your password:
https://skyid.sky.com/resetpassword/
Then go to this link:
https://skyid.sky.com/authorise/manage
If you tick "Sky Apps" and then the remove button, then anyone using SkyGo or SkyNews or SkySports apps etc. using your credentials will have the previous auth token removed and will be forced to sign in again (using the new password only you know). Will mean people you want to use your ID will need to do the same, but will force whoever is using your previous details off, this might not stop them straight away but it will over a day or so.
@loucamp80
Try this:
This message was authored by Parj This message was authored by: Parj
Out of interest did this work?
It should do @Parj so if you follow it step by step then within a few days whoever you want to stop will be blocked.
This message was authored by Haze58 This message was authored by: Haze58
Hi, i removed SKY GO as someone was using it, however now I  cannot acess manage my devices via my iphone is there a way to add SKY GO back onto my list of apps.
How did you do this so what did you do ?
Not qute sure what you mean, just log back into Sky Go if you haven't done this yet.
You can also manage your devices onlie here:
https://www.sky.com/productsettings/tv
This message was authored by Blackwidow53 This message was authored by: Blackwidow53
Thankyou
i have. Followed instructions  changed email and followed link to remove tick from my app .
i understand I have to wait a few days
Can you let me know how to find the my apps as since removing tick the link says error
thakyou in advance x
@Blackwidow53
Did you use this link:
I used this from your post x
If you have done that then you don't need to do it again as it should start working in a day or two.
On average, new discussions are replied to by our users within 3.6 hours
