This discussion topic has been answered Discussion topic: Why are there no BBC Channels listed on Sky Go?
Message posted on 26 May 2023 09:27 PM
I have Sky Go on my Laptop but when I go into it there are no BBC Channels showing on the listing.
Message posted on 26 May 2023 09:46 PM
When in the TV Guide select "Record to Sky box" then you will see them. That apart when using the app away from home it is not possible to watch the BBC channels as the BBC themselves will not allow then to be shown via the Sky Go app as they want people to use their own iplayer app. You can view them when at home if you have a Sky Q box and a multiscreen sub as the app will then connect to your Q box so they can be streamed from it.
Message posted on 15 Jan 2024 10:02 AM
Re: Why are there no BBC Channels listed on Sky Go?
I have this problem regularly and by closing the app and restarting it usualiy fixes it but not always, not sure why but it seems to be, might be when internet signal is weak, also reinstalling the app can fix it, or combination of these things, which is all irritating.. I dont use it out of the house so not sure if any problems using this mobileout. False statements such as BBC has withdrawn its use on Sky is nonsense. I am watching beeb now in sky go.
Message posted on 15 Jan 2024 11:21 AM
@Feedbackonsky wrote:False statements such as BBC has withdrawn its use on Sky is nonsense. I am watching beeb now in sky go.
Not sure anyone as claimed this at all. As mentioned in the previous posts BBC live streaming will only work if you are at home and have a Sky Q box which your Sky Go app is connected to.
Message posted on 15 Jan 2024 11:30 AM - last edited: 15 Jan 2024 11:32 AM
BBC channels are not listed in Sky Go for a Q user when away from home (or at home but on cellular data rather than Wifi), or in Sky Go for a Glass/Stream user at all. This is a choice made by the BBC to increase iPlayer use.
Message posted on 15 Jan 2024 11:33 AM - last edited: 15 Jan 2024 11:34 AM
If your device is using cellular data rather than WiFi when Go starts up, that would be precisely why BBC channels don't appear: it isn't detecting a Sky satellite box on the same network, so goes into 'away from home' mode.
Message posted on 15 Jan 2024 01:24 PM
To make it clear the BBC channels will not appear for live tv viewing when away from a Sky Q box. This isn't anything new as this has always been the case.
The channels should appear for remote recording but as stated they are all over the place from 802 and 951 onwards.
Message posted on 28 Jan 2024 02:36 PM
It's most annoying, although some people are saying they are on different numbers it's not on mine at all.
I have just had to delete the Sky app that I had as it wasn't showing the tv guide at all but the only app I can get now is Sky go so no recording BBC from it.
Message posted on 28 Jan 2024 04:15 PM
You can remote record the channels by following what I posdted above and make sure you select "Record to Sky box" at the top of the TV Guide first.
Message posted on 28 Jan 2024 04:18 PM
Yes maybe but I can't see what's on. If I put say Traitors in the search box I can get it but I want to see the list of what's on all day....
Message posted on 28 Jan 2024 04:28 PM
If you want to see what is on a certain channel then you have to go to the channel in question so 801 for BBC One and then you can see the full days programming.
Message posted on 28 Jan 2024 04:30 PM
Mine goes from 707 then 803......
Message posted on 28 Jan 2024 04:35 PM
That is because you haven't selected "Record to Sky box" at the top of the guide.
Message posted on 28 Jan 2024 04:43 PM
Doh, how did i miss that bit, must be an age thing.....thank you so much xx
Message posted on 29 Jan 2024 02:08 PM
@blossom52 Sky have now updated Sky Go and BBC1 HD and BBC2 HD are now at 101 and 102
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
