Discussion topic: Technical fault
This message was authored by: Genine1
Technical fault
I haven't been able to get sky on any of my tv's, mobile device or laptop it keeps saying technical fault. I have rebooted WiFi, restarted everything and it still isn't working.
Re: Technical fault
Is this a Sky GO issue (the forum you posted in)?
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
This message was authored by: Felix+Cited
Re: Technical fault
I've had the same issues, unable to stream using sky go
Re: Technical fault
Thanks for sharing but does not nelp with my question though 😞
Re: Technical fault
@Felix+Cited
Has it been working up to now or are you new to Sky ?
Avatar for Genine1
Re: Technical fault
 I unplugged everything for 5 mins, restarted it and thankfully it's working now.
See if that works for you.
This message was authored by: Antony28
Re: Technical fault
I am getting intermittent  connections to my phone and tablet no connection or saying waiting fo network connection to establish
