9
This discussion topic has been answered Discussion topic: Sky stream / sky go
This message was authored by: Jacko1968
Sky stream / sky go
Hi
I have sky stream and want to download some films etc on my iPad and mobile. When I try to do this via my sky go it comes up with this message ? It worked perfectly when I had sky Q
the tech team are saying that as there is no hard drone as such on the sky stream you can't download on iPad ? Does this sound correct??
any help would be much appreciated
Re: Sky stream / sky go
@Jacko1968
You can setup a pin for Sky Go use here:
https://www.sky.com/productsettings/tv/parental-controls
Yes that's correct. On your stream box just search for it and the episode will be there ready to stream, no need to download to a HDD
But you should be able to download episodes to your iPad or phone still. The message implies you need to set a pin first.
Avatar for Jacko1968
You would like to think so but have changed pin reloaded both apps on iPad and iPhone with no joy.
sky tech seem to think that you can't download on the devices from sky stream only from sky q but they were very unsure which I find amazing
I've checked mine and I can't download either. Odd. This might be better in the Go forum than stream, maybe a moderator can move it for you.
This message was authored by: Hunter2660
I can download to my iphone and pc, so something odd happening there.
@Jacko1968
Perfect. Downloads work after using that.
The confusion is likely to be over the terminology.
Sky Q has a hard drive, so it's possible to transfer data files from there to a Go client device over the local network: whether this is a 'download' is debatable.
Sky Glass / Sky Stream has no local storage, so any data arriving into Go is from Sky servers over the internet and that is a 'download'.
This message was authored by: AnthonyF1
Thanks for this, I was having the exact same problem and the suggested fix from Sky Go and Google was useless. This worked instantly. Off on holiday on Friday and want to watch The Sopranos on the plane!
