Discussion topic: Sky go technical fault
This message was authored by: Darren194
Technical fault on sky go app, cannot watch any channel, movie or anything on any device.
have deleted app, refreshed Apple TV and iPhone, have tried signing in and out, checked for updates, all updated and ok. Please help why can't we sign in?
Re: Sky go technical fault
@Darren194
Has it been working up to now or is this the first time you are attempting to use it ?
Avatar for Darren194
I have been using it fine up until now
This message was authored by: trendkill82
Try this....
Go to here, and uncheck "Sky GO Apps"
https://skyid.sky.com/authorise/manage
And then re log in.
This message was authored by: Craigy092
Sky go won’t work
Sky go was working fine since yesterday night now sky go won't load anything on my Xbox when I try it gives me a message saying "sorry there is a problem playing the selected video, access from this household is restricted" it says that even when I try to load the kid's channels then when I try to load sky go on my mobile I get an error saying " because of a technical issue you cannot watch this content" I have whole home subscription sky ultimaye tv both my pucks are working fine everything is except sky go since yesterday can someone else before I have to call sky?
This message was authored by: 5StarCales
Re: Sky go won’t work
Got exactly the same problem. Only found out just as the football was starting 🙄
So it's not just happening to me then it must be a problem sky end  I'll be ringing them tomorrow to find out what's going on
This message was authored by: teknys
I cant wtach through my virgin sign in either
Are you with virgin for your broadband?
My sign in works fine on windows11 but it takes me to the upgrade to skysports screen which I have had since time began!!
This message was authored by: Lfctigger
Sky Go not working
Anyone else have issues watching any channel in sky go keeps coming up with a technical issue
This message was authored by: Auntyemma95
Sky Go App
I cannot access the Sky Go app on any device. I can watch sky sports + using my log in but not actually log into Sky Go on my phone, husbands phone, ipad or tv! Help!
Re: Sky Go App
On those devices what is happening ?
This message was authored by: JoK73
Re: Sky Go App
Same I can't access sky go app on any of my devices!
Re: Sky Go App
@JoK73
So same question as above - what is happening ?
