Discussion topic: Sky go not authorised
This message was authored by: Steve1938
App keeps showing not authorised, check internet. Internet connection always fine. This is the first time this has happened. Reloaded app but no change. ????? Thx Steve
This message was authored by: SueR68
Re: Sky go not authorised
I am having same issue on my iPad
Are you using a VPN, because if you are it will need disabling.
Not using VPN
