Discussion topic: Sky go device pin not working
Message posted on 07 Sep 2023 05:10 PM
I've seen a few posts on here but no resolution.
Downloaded shows to watch offline on plane.
Get on plane and asks for pin, no idea what this was so can't watch. I've since been online and set up pin and can watch shows without the pin when online.
When I go back offline I can't watch anything as it isn't recognising the pin number.
How do I get round this? Seem to be in an endless loop hole that only allows downloads to work online, which defeats the object!
Please help!
Daniel
Message posted on 07 Sep 2023 05:11 PM
							Re: Sky go device pin not working
If you are not in the UK then you can reset your Sky Go pin here:
https://www.sky.com/manage/tv/manage-devices/change-pin
Message posted on 07 Sep 2023 05:15 PM
Thanks but I already tried this and still isn't working when I am offline
Message posted on 07 Sep 2023 05:17 PM
Have you gone online to watch something first as I should image you will need to do this so that the pin can update on the app.
Message posted on 07 Sep 2023 05:19 PM
I have been online yes, still doesn't seem to be updating in the app
Message posted on 10 Oct 2023 01:54 PM
Did you get a resolution to this as I am having exactly the same problem! It seems a lot of people are but I haven't seen a solution to it yet!
Message posted on 13 Jan 2024 10:09 AM
Does anyone have a resolution to this issue. Sky PIN works on the Sky Q box but on the app it says Incorrect PIN
Message posted on 13 Jan 2024 10:15 AM
The solution is posted here, your TV pin and Sky Go pin might be different.
Message posted on 28 Aug 2024 06:14 PM
I have just had this problem downloaded stuff to watch in the plane kept asking for the pin wouldn't accept the sky pin. Yet when I was abroad it accepted the pin and let me watch. Why won't it work on the plane?
Message posted on 22 Sep 2024 05:00 PM
Thank you. Worked perfectly
Message posted on 02 Oct 2024 07:14 PM
I face the same issue. So annoying.
Message posted on 02 Oct 2024 07:29 PM
Does the reset link I posted earlier not work for you ?
Message posted on 20 Nov 2024 08:22 PM
No you can't, the link takes you directly to your products and if you click through takes you to the shop. Ridiculous, it's been like that for ages. No one is monitoring this
Message posted on 20 Nov 2024 08:28 PM
That is because that is an old post you have found as the link has now been changed to this one:
https://www.sky.com/productsettings/tv/parental-controls
Message posted on 25 Mar 2025 04:34 PM
Thank you someone actually knows what there doing ive used the link and updated the pin thanks alot 👍
