4
This discussion topic has been answered Discussion topic: Sky Go won’t load on laptop
This message was authored by: Robin70
I am trying to get Sky Go on my laptop but it doesn't work. I get error code PFE 4002
Avatar for Robin70
This message was authored by: Robin70 Answer
Re: Sky Go won’t load on laptop
Thanks but app wasn't loading so couldn't do as suggested. Resolved issue by deleting all references to Sky Go on laptop and then reinstalling.
Give this a try:
Right-click on the Sky Go app and click on Compatibility.
Go to change settings for all users at bottom of pop-up.
Check the boxes "Run as administrator" AND the box beneath that says "Register this Program for Restart".
Click Apply.
Relaunch Sky Go.
Avatar for Robin70
This message was authored by: Kris2018
ok for everyone who doesnt have very good knowledge with windows and errors with programs.
the first thing is to delete the program
and then delete the leftover files and folder C:\Users\pcname\AppData\Roaming and regedit
a program called ccleaner will do this when installed go too tools then registry then scan for issues and fix keep doing this maybe 2 or 3 times until theres no more issues then re download a new sky go app from sky website install and login worked for me and ccleaner is also safe i have used it for many years on and off
This message was authored by: Andy.C.Clark
I have the same problem (yet again) with a PFE4002 error.  I followed the idea of completely uninstalling (using REVO) but to no avail.  the programme loads, and I can select (say) the 401 Sky channel but all I get is a black screen with a rotating circle.  I've also tried starting the programme as adminstrator.  Does anyone have any more suggestions?  I'm running Windows 11 24H2, build 26100.4946.
Answered - Go to Answer
