Discussion topic: Sky Go will not launch on Mac
This message was authored by: John583
Same as previous posts where on selecting the Sky Go icon it bounces a couple of times in the Dock and then disappears. I have unstalled and re-installed the Sky Go app with same result. My Mac OS is Ventura 13.1
Re: Sky Go will not launch on Mac
@John583
Does this work for you:
https://helpforum.sky.com/t5/Sky-Go/Sky-Go-still-not-working-on-Macbook-Pro-with-Sequoia/m-p/4916701...
Avatar for John583
Thanks for the response.
The process goes through installing and completes with the following but unfortunately produces the same result.
installer: The software was successfully installed......
installer: The install was successful.
Sky Go - Installer[4483:120028] path:/var/folders/h6/drj2yhmn5fl8d5mb84pgcj200000gp/T/tmp-SkyGo_production_26.1.3_gb_production.pkg
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Deleting expired sessions...       5 completed.
[Process completed]
This message was authored by: SJJ4
Suggest you give up I've tried for 3-4 years and no positive result. I've actually had one person say why complain you do pay for sky go
Avatar for John583
A sad state of affairs as I reported the same problem 12 months ago and would have thought Sky would have come up with a solution over time.
