Discussion topic: Sky Go Freezing on Pixel 10
This message was authored by: EamonnOS
I have recently gotten a Google Pixel 10 which has Android 16 and when I try to watch anything on Sky Go it starts playing just fine and then after a ten seconds or so the picture freezes while the sound carries on as normal.  This is happening on 5G and WiFi.  All other apps, including Sky Sports, work as expected.  It is only Sky Go with this issue.
Is this happening to anyone else and is there a solution?
This message was authored by: Bod
Re: Sky Go Freezing on Pixel 10
Hi I have a Pixel 6 which has the same problem!  It seemed to begin following the Android 16 update - Prior to this it was working fine.
Avatar for EamonnOS
Thankfully it is not only me so.  Can someone at Sky investigate this please.
@EamonnOS
You can report this to them via this email address - [email protected]
This message was authored by: Anokha
I have pixel 10 with android 16 and the Sky News Live vedio freezes whilst the audio continues to work fine.
Sky news Live works fine on other older android OS/phones.
