3
This discussion topic has been answered Discussion topic: Sky Go will not launch in Mac OS
This message was authored by: garfybedss
I know this is a subject which has been discussed frequently before, and Sky have announced they have launched a fixed version of Sky Go that works on Mac OS.
I have a 2017 MacBook Air running MAC OS Monterey, which I purchased recently.  Yesterday I reinstalled the OS to ensure it was clean, and Sky Go installed and launched.  This caught me by surprise as I had had issues before with my 2015 iMac running Mac OS Monterey, but I also installed Sky Go on that yesterday and it launched without issues.
Today, I installed a new SSD in the MacBook Air (a genuine one) and reinstalled Mac OS Monterey.  However, when I install Sky Go, it runs the download, then the install, then it it flashes twice as launching then goes completely dead.
I have tried all the advised de-installs and clearing out Library folders but it just keeps doing the same.
Avatar for garfybedss
This message was authored by: garfybedss Answer
Re: Sky Go will not launch in Mac OS
For anyone who has the same problem - I found the fix by looking around.
It seems CSR Utilities were not in the correct state:  try checking out the current status by opening terminal and typing "csrutil status" without quotes.
If it says anything different from "System Integrity Protection status: enabled.", use my procedure above or google (acknowledge Ludowing for this step). To renable I followed these directions: https://www.kolide.com/features/checks/mac-system-integrity-protection.   I  cleared the BSKYB entry in ~Library/Application Support and the BSKYB contents in ~Library/Cache and uninstalled the app in ~Users/YourUser/Applications  Then I did the CSR Utils reset and rebooted and it installed ok
This message was authored by: Addie15
This message was authored by: Lichto
Thanks garfybedss.  After a year of trying to resolve this issue on 2 diffrent Macs, it transpires that they both had System Integrity Protection disabled! Would never have come across that without your help. Thank you!
