Discussion topic: Sky Go technical error
Message posted on 29 Sep 2025 02:19 PM
Sky Go not working on any of our apps. 'Because of technical error, please try later.'This has now been 2 days and still not working. Sky said it would be fixed by 2.30pm yesterday, then 24hours but we still have no service.
Message posted on 29 Sep 2025 05:07 PM
Re: Sky Go technical error
Try signing out of the app then reboot your device and then sign back into the app.
If that doesn't work then try linking your Sky ID to your account, help on doing this can be found here:
https://www.sky.com/help/articles/sky-id-cant-access-all-my-services
Message posted on 29 Sep 2025 06:26 PM
I have contacted Sky who have said it is a technical fault and they're dealing with it. Could take a further 24-48 hours. Does anyone else have the same issue?
Message posted on 29 Sep 2025 07:34 PM
They are fobbing you off as they will say that when they do not know of a fix so what happens when you try what I posted above ?
Message posted on 29 Sep 2025 09:26 PM
Mines not working on the Xbox, everything else does though.
Message posted on 30 Sep 2025 08:15 AM
Yes I tried everything, still no joy. Thank you.
