Discussion topic: Sky Go on PC not launching
This message was authored by: Clev62
Sky Go has stopped working on my Win11 Pro build 23H2 desktop pc.  I think I last used it a few weeks ago as I tend to watch on my Samsung tablet more often.
When I try and run the app it opens with a white screen, hangs for a few seconds then closes down. I don't get any error messages.
I have read this forum and tried many solutions including multiple reinstalls, changing the app properties, restoring previous versions, clean and thorough uninstall including the registry. I've deleted VLC player, cleared the Temp folder in AppData\Local. I've followed one suggestion of creating a new user and installing Sky Go in there with exactly the same outcome.
The Sky Go app is version 24.1.3.0 pubhlished 20/05/2024.
Does anyone have any other ideas on how to get this working again please?
Thank you
This message was authored by: RFS123
Re: Sky Go on PC not launching
Hi @Clev62
I tried moving to the beta version 24.1.3.0 from settings, but the new version still did not work.  Today that version has been updated to 24.2.2.0, but I don't know yet if that fixes the issue.
This is the problem I see - clearly a software fault (exception code is addressing exception)
Faulting application name: Sky Go.exe, version: 24.1.3.0, time stamp: 0x650068b3
Faulting module name: Sky Go.exe, version: 24.1.3.0, time stamp: 0x650068b3
Exception code: 0xc0000005
Fault offset: 0x037cdb7a
Faulting process id: 0x20AC
Faulting application start time: 0x1DB12615FC8058C
Faulting application path: C:\Users\Robert\AppData\Roaming\Sky\Sky Go\Sky Go.exe
Faulting module path: C:\Users\Robert\AppData\Roaming\Sky\Sky Go\Sky Go.exe
Report Id: 26150733-91d3-4ca6-8f26-c3f6e52495b5
R
Avatar for Clev62
Level 2 icon
Hi @RFS123
Thanks for the post. Where did you find a beta version? Also the update to 24.2.2.0 - I've tried from the Sky Go download link and it's still 24.1.3.0?
As I've mentioned in a second post, the only time I've managed to get this working is by creating a new Windows virtual machine with nothing else in it apart from Sky Go.
And I've never had any error messages or Sky Go stuck in "updating" - I just get an app window opening, waits a few seconds, then shuts down again.
Hmm
Hi @Clev62
You can install the beta version by going to settings ->updates from the start screen..  Quite easy to do - and undo if you're not happy with the version.
The problem I see is a black screen on start-up and then it shuts down with the error shown in the log,
R
Avatar for Clev62
Level 2 icon
Hi @RFS123
I assume you mean Settings, Update in the Sky app? Sadly the app doesn't launch beyond  a window opening with Sky Go in the title bar before it shuts down again.
So I never get a chance to do anything further with it.
Hi @Clev62
Yes that's also the problem I see. But I've found thast if I keep trying it usually starts eventually.
R
This message was authored by: Gordon4711
I have same problem that SkyGo does not Launch on my PC. Uninstalled & Reinstalled ..goes through Process of Updating. Never get to point of being able to Login & provide Password .. eventualy crashes with error message 001
This message was authored by: twilight+princess
Have you tried using Revo Uninstaller to cleanly remove Sky Go & scan for leftovers then install a fresh version of Go?
Try Revo uninstaller free:
https://www.revouninstaller.com/products/revo-uninstaller-free/
The uninstaller will run the program’s own uninstaller then allow the user to run a ‘scan for leftovers’, if the uninstall fails you can still scan for leftovers which will then be akin to a forced uninstall & will remove the program.
For Apps these are shown under their own tab at the top - Windows Apps.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
Hi twighlight +princess
I ran the uninstaller as proposed & also searched for Leftovers & it seem to find which I then deleted. I then rebooted & installed Skygo again. Unfortunately same issue that Skygo app installed ..then said " updateing software " then continued with the Blue screen until it ends with the Error message window 001 !
Any other things to try ??
Thanks for trying then it's most likely a problem with the app rather than the device.
Virginia.
Hi @Clev62 and @Gordon4711
There is one thing you could try. Disconnect your PC from the internet and start Skygo. It might be that the error occurs connecting to your Sky box. If it comes up, it will be in offline mode. You can then re-enable the internet which should cause it to fully initialize.  If you're lucky and that works, you can then go to updates and install the beta 24.2.2.
I've been running this version on PC and laptop today, frequently starting and stopping it, and can no longer recreate the failure.   Looking good so far.
R
Avatar for Clev62
Level 2 icon
Nice idea but sadly still no joy, the app still refuses to launch. Guess I'll wait for the beta to go live and see what happens then.
Many thanks for the suggestion though.
Hi @Clev62
Well I've been trying it all weekend, but just now it failed with the same problem. So it's still not fixed even in this beta..  I tried to start it again and all was well, so it's an intermittent problem for me. Same fault offset as with previous version..
Description
Faulting Application Path: C:\Users\Robert\AppData\Roaming\Sky\Sky Go\Sky Go.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: Sky Go.exe
Application Version: 24.2.2.0
Application Timestamp: 650068b3
Fault Module Name: Sky Go.exe
Fault Module Version: 24.2.2.0
Fault Module Timestamp: 650068b3
Exception Code: c0000005
Exception Offset: 037cdb7a
OS Version: 10.0.26100.2.0.0.768.101
Locale ID: 2057
R
