13
This discussion topic has been answered Discussion topic: Sky Go not working on Wifi
This message was authored by: sazag
When I'm on my Vodaphone home Wi-Fi my sky go doesn't work on any device. Drop to 5G also supplied by vodaphone, works as normal. Error message- "Sorry, something went wrong. There is a problem streaming this show. Please check your network connection and try again. Error code: 17d"
Avatar for sazag
This message was authored by: sazag Answer
Re: Sky Go not working on Wifi
I have had the issue resolved. I spoke to Vodaphone, my router was re-set. I turned the rouer off and on again. Now all divices will play Sky apps. All fixed
Are these Apple devices by any chance ?
Avatar for sazag
Yes, phone, MacBook and ipad
If you are using a VPN it will need disabling, other than that try signing out of the app, rebooting the iPad and Mac then sign back in to see if they will work,
This message was authored by: Forch
Having the same problem. Works on mobile network but not on WiFi. Only started happening recently. Works on other devices over WiFi but not iPhone. Re-installed app but still the same.
Did you try disabling the Wifi connection @Forch then deleting the app, rebooting your iPhone, turning the Wifi back on before installing the app again ?
Yes I tried that. Also tried on 2 different WiFi networks and doesn't work on both
This message was authored by: Hug
I am getting this message on iPad and iPhone when watching on Sky go
Sorry, an error occurred. Please check your internet connection and try again.
Error code:
I have gone through all the procedures as advised by sky and none have worked.
This message was authored by: Rob+Hemp
I have the same issue....very poor from sky! Nothing I do can resolve it?!
Avatar for sazag
I deleted the app and reinstalled and it ended up working in the end.
This message was authored by: Calvin101
Am having the same issue on all devices. No shows or channels will play or download over wifi, but will on 5G. Same issue on numerous wifi networks. ANyone got any ideas? I've tried all the usual, delete app, sign out, rebbot stuff. Still won't work.
This message was authored by: FinolaHayes
Did you get this resolved as I currently have the same issue. Works via 5G but not home WI-FI
This message was authored by: Maisie241
Did you ever find the issue and how to fix it? As I'm struggling with the same thing. Won't play anything on WiFi
Answered - Go to Answer
