Discussion topic: Sky Go not streaming
This message was authored by: AndrewMc13
  • As of this morning Sky Go is no longer working on my mobile or XBox. When I open a channel I just get a spinning circle.
Avatar for AndrewMc13
Re: Sky Go not streaming
I have rebooted devices and router, reinstalled the app and tried a different WiFi network but still get the same issue.
Try using a different dns (1.1.1.1 / 1.0.0.1)
This message was authored by: Aden85
My sky go is also not working as of today which is annoying because we are in the process of moving and are using the Xbox to watch tv while we wait to set things up properly, third time this week it has failed, will probably be cancelling the contract if this continues
I tried the different DNS but still no joy
Have you tried Sky Go using your mobiles data rather than your broadband?
Switching to data on mobile does indeed allow me to connect via Sky Go. The WiFi networks tested earlier are entirely separate but provided by the same ISP.
Sounds like mobile data is being routed differently that broadband, at least you know the app is fine and the issue is with the Internet connection
Maybe contact your ISP with your findings so far
I'll try that, thanks
