12
This discussion topic has been answered Discussion topic: Setting up a device PIN
This message was authored by: Louise210
I'm trying to download a programme on Sky Go, in order to do so it says I need to set up a device PIN and gives a URL. When followed this takes me to a help page which says login and click on parental controls then choose age rating and a device PIN (different to a Stream PIN). I'm logged into MySky but can't find these menu options anywhere and I'm going round in circles!
Re: Setting up a device PIN
@jajamj
Very odd as when using the link I posted earlier I see this:
https://www.sky.com/productsettings/tv/parental-controls
@Louise210
It should be this link you need to use:
Avatar for Louise210
Thanks but this doesn't work, product settings takes me to a choice of sky stream or phone and when I click on sky stream it then shows me the puck and 2 devices - none have parental control options!
Very odd as it works for me as it shows "Content Age Rating" under parental control for me.
This apart does Sky Go work ok for you so you can access your channels without any issues ?
This message was authored by: jajamj
Did you sort this out?  I have the same issue and can't figure out how to solve it
This message was authored by: Jimmymac1951
I have the same problem it just sends you in circles.  If anyone know the answer please help
@Jimmymac1951 @jajamj
This topic is about setting a pin for Sky Go so is this what you are trying to do ?
Yes. Sky go. Trying to download episodes to iPad. Sends me to set a device pin. I have no options for a device pin anywhere on line or on the sky go device.
@jajamj
This message was authored by: SHANELEECH
Setup your pin
Hi Shane - didn't get your reply. I'm still stuck and can't download to any device. I don't have an option to set a mobile pin anywhere.
@SHANELEECH wrote:
Setup your pin
@SHANELEECH
Have you seen the post above yours ?
This message was authored by: Charl_
