Discussion topic: Problems using sky go
This message was authored by: Carr25
I've tried using sky go recently and it keeps telling me to upgrade my subscription however it's included in my subscription does anyone know how do fix this issue?
Re: Problems using sky go
If you are using Sky Go on a Games Console then take a look herer
https://helpforum.sky.com/t5/Sky-Go-Apps/Sky-Go-not-working-on-your-console-Xbox-PS4-5-etc/td-p/4311...
If not I could escalate to the Sky Messaging team for you if you like
Avatar for Carr25
Hi no I'm using my phone is you could that would great thanks 👍
I have escalated your post to the Community Messaging Team
Check out the link below that explains the process
Escalating a post to a Sky expert
Note: you have 48 hours to reply once you have the invite (if you don't reply in time your invite will be automatically closed). Once you have replied you might have a little wait for a team member to get back to you
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent Carr25 an invite.
Update-We are closing this session now but if there is anything else we can help you with, please do not hesitate to reach out. Thanks.
This message was authored by: 62
For the same problem ere to mate.
@62
Which of these do you have on your account:
Multiscreen
Sky Go Extra
Whole Home package
Hi mate. Sky go extra.
Are you a Sky Q or Sky Glass/Stream customer ?
Sky stream.
In that case you also need the Whole Home package on your account before you can use the app on a console.
Arrh right. But how come it works on my phone OK??
The whole home sub isn't required to access Sky Go on a mobile or tablet but is on a console.
