Discussion topic: Phone won't connect sky Q
Message posted on 02 Nov 2024 12:16 PM
Message posted on 02 Nov 2024 12:26 PM
Re: Phone won't connect sky Q
Same as another thread. Weird.
Just tested mine and it's fine. I'm on iOS 18.0.1 and I see there's an 18.1 update though...
Message posted on 02 Nov 2024 12:33 PM
Everything is updated. Turned phone off and on, uninstalled and reinstalled app. Using android phone. Read somewhere that you have to have sky Go extra but never needed this before!
Message posted on 02 Nov 2024 12:54 PM
Yeah I meant maybe mine works because it is NOT updated to the latest.
Message posted on 02 Nov 2024 01:26 PM
You don't need Sky Go Extra to be able to connected the Sky Go app to your Sky Q box but you do need multiscreen so do you have this on your account ?
Message posted on 02 Nov 2024 05:08 PM
Sky Go won't connect to Q Box
Message posted on 02 Nov 2024 05:12 PM
Re: Sky Go won't connect to Q Box
I have moved your post to your ones from earlier, so can you answer the question I asked above yours.
Message posted on 02 Nov 2024 05:49 PM
@Chodley wrote:Yeah I meant maybe mine works because it is NOT updated to the latest.
So much for this theory. Upgraded to 18.1 and still works fine.
Message posted on 03 Nov 2024 05:30 PM
emails now going there and back to Sky whilst they ask me the same questions over and over and I carry out the same processes with no success. Everything is connected correctly, we have multi room and in the sky setting everything that should be ticked is. Says I should be able to watch tv through Sky Q and mini box but search deson't bring my phone up. We are connected the same wifi, so emails will continue.
