Discussion topic: PS4 not showing sky go
This message was authored by: Westover65
Hi, I'm trying to download sky go for the PS4 but it doesn't come up when I search for it.  My son has ps5 and had no trouble finding it.
Re: PS4 not showing sky go
Search  for "TV from Sky"
Avatar for Westover65
Yeah I've done that, nothing is showing.
I don't believe app searching via the PS4 Playstation store particularly works.
If you open the playstation store on your PS4, then scroll down to Apps, press X twice and you can then navigate the app library. The Sky Go app is listed on about the 10th row down for me.
Thanks I'll try that. Just find it weird that my son found it straight away on his ps5.
