Discussion topic: How do I add a device to my Sky Go permissions
This message was authored by: naevesdaddy
I can see how to remove a device from Sky Go. Cureently I have 2 devices connected. How do I remove one of the devices please?
Re: How do I add a device to my Sky Go permissions
There shouldn't be any need to remove a device because if it isn't being used then when you reinsurer another one it will take its place.
If you still want to remove it then you can do this via Settings > Manage your devices via the Sky Go app.
To add a device as per the subject header simply start watching a program through sky go on your chosen device
This message was authored by: Jayjay13
I  have a new phone and want to change my skygo
@Jayjay13
What do you mean by "change my sky go". To use Sky Go on your new device just install the app on it and watch something. If you want to remove the old device then you can do this here:
https://www.sky.com/productsettings/tv
