10
This discussion topic has been answered Discussion topic: Error Code 1410 Sky Go
This message was authored by: Baz.W62
I have a premium membership with all channels included and have done for a number of years. I have a macbook that I have been using SkyGo on, however, out of the blue it has started showing error code 1410 whenever I try to use it. It says that the relevant package is needed, but I have everything included in my subscription. I have tried uninstalling and reinstalling the app to no avail. Can someone advise me on how I can fix the issue please?
Avatar for Baz.W62
Level 0 icon
This message was authored by: Baz.W62 Answer
Re: Error Code 1410 Sky Go
Problem sorted via sky support.
Avatar for Baz.W62
Level 0 icon
This message was authored by: StokeBunnie
I have a full Sky package including Sports, but cannot access SkyGo on my laptop.  It works fine on my phone.  Please refer to Sky
KRgds
Chris
Are you getting a 1410 error, if so are you using the correct login details ?
@caesarome I can get this far, but no further.  As I can see the home page, and have signed in, surely I must have the correct logon?
Can you also disable the connection to your Sky Q box to see if it then works.
@caesarome No, that didn't work, same error
This link explains how this works:
When the chat bubble does appear you have 48 hours to respond or it will be automatically closed. This isn't a live chat so replies are not instant.
This message was authored by: Tom-W19
Thanks for escalating. We've sent an invite to StokeBunnie.
Tom
Many thanks to @Tom-W19  for his assistance.  Re-installing the app worked fine
