This discussion topic has been answered Discussion topic: Error Code 1410 Sky Go
Message posted on 09 May 2023 08:55 PM
I have a premium membership with all channels included and have done for a number of years. I have a macbook that I have been using SkyGo on, however, out of the blue it has started showing error code 1410 whenever I try to use it. It says that the relevant package is needed, but I have everything included in my subscription. I have tried uninstalling and reinstalling the app to no avail. Can someone advise me on how I can fix the issue please?
Message posted on 09 May 2023 09:00 PM
Problem sorted via sky support.
Message posted on 30 May 2023 03:03 PM
Re: Error Code 1410 Sky Go
I have a full Sky package including Sports, but cannot access SkyGo on my laptop. It works fine on my phone. Please refer to Sky
KRgds
Chris
Message posted on 30 May 2023 04:13 PM
Are you getting a 1410 error, if so are you using the correct login details ?
Message posted on 30 May 2023 04:45 PM
@caesarome I can get this far, but no further. As I can see the home page, and have signed in, surely I must have the correct logon?
Message posted on 30 May 2023 04:48 PM
Message posted on 30 May 2023 04:48 PM - last edited: 30 May 2023 04:49 PM
Can you also disable the connection to your Sky Q box to see if it then works.
Message posted on 30 May 2023 05:09 PM
@caesarome No, that didn't work, same error
Message posted on 30 May 2023 05:11 PM
This link explains how this works:
When the chat bubble does appear you have 48 hours to respond or it will be automatically closed. This isn't a live chat so replies are not instant.
Message posted on 31 May 2023 09:05 AM
Thanks for escalating. We've sent an invite to StokeBunnie.
Tom
Message posted on 31 May 2023 12:20 PM
Many thanks to @Tom-W19 for his assistance. Re-installing the app worked fine
