Discussion topic: constant connection issues
Message posted on 25 May 2025 06:45 AM
Re: constant connection issues
@paul9115 It could also be related to this issue:
See the marked answer and try logging out of Prime Video before you turn the TV off. Those of us affected by this issue seem to think it's Prime Video causing the problem.
Message posted on 26 May 2025 06:50 PM
Sorry, not the solution, at least not for me. I got the No WiFi connection just three hours after doing this. I cannot wait for my credit agreement to be paid off so I can get rid of this heap of junk!
Quickline FTTP 500Mb/s Download and Upload.
Message posted on 26 May 2025 06:59 PM - last edited: 26 May 2025 07:00 PM
@Magic+Cottage Sorry it hasn't worked. Some have found logging out of Prime Video rather going in and out of the app and then doing a Restart via the Settings (not factory reset though) stops the issue. It's a pain to do this but until Sky fix the firmware issue it's been the best workaround for this issue.
Message posted on 27 May 2025 11:25 AM
I've had some success with disabling overnight power saving as well, again it's really not an ideal solution, but it's been stable for me over the last few days.
Message posted on 30 May 2025 01:17 AM
I have been having this issue the last couple of months at least with my Sky Glass. Screen goes blank then states program loading then tells my I have no internet connection. Have to restart the tv. There is no issue with my internet it's stable. Also the tv has buffered many times and got stuck and then re set itself. It's a pain considering how much it cost. O wish I hadn't of bothered with it now
Message posted on 30 May 2025 06:42 AM
@JaxS wrote:I have been having this issue the last couple of months at least with my Sky Glass. Screen goes blank then states program loading then tells my I have no internet connection. Have to restart the tv. There is no issue with my internet it's stable. Also the tv has buffered many times and got stuck and then re set itself. It's a pain considering how much it cost. O wish I hadn't of bothered with it now
@JaxS What internet connection do you have ? What speed is getting to your tv ?
Message posted on 16 Jun 2025 05:21 PM
Same! Every day I have to reset it. Getting fed up with bog standard answer from sky of switching it off and back on again. Come on sky these services are expensive! No other device in the house is affected. Ethernet cable connected or not it's the still same
Message posted on 16 Jun 2025 05:48 PM
Fact of the matter is that Sky couldn't care a monkeys otherwise this would have been sorted a long time ago.
Message posted on 10 Jul 2025 07:42 AM
I have exactly the same product, problem and same excuses from sky!
Sky community is full of people having the issue yet sky are unwilling to except they have either a faulty product or a faulty software update loaded that is causing the issue.
I will not just shut up and go away, my internet is fine and the only issue is sky tv. I refuse to accept everybody having the issue, are all having internet problems!!
sky need to sort this out, consumers rights say a faulty product is a breach of contract!
Message posted on 10 Jul 2025 09:05 AM
thanks for sharing your frustration on this as well. If you get any joy from sky can you you keep me posted on it? As you rightly say, faulty product, breach of contract.
Message posted on 10 Jul 2025 10:24 AM
I hate to say these things but good luck with your campaign but I have severe reservations that Sky will respond or even care.
Message posted on 11 Jul 2025 10:11 AM
Yeah I'm inclined to agree with you tbh. Very frustrating, quick enough to take money from us and increase our costs.
