3
This discussion topic has been answered Discussion topic: Replacement remote
This message was authored by: Reevo87
Replacement remote
I have requested for a replacement remote. Had the email to say it would be reviewed and then a text message to say it was on its way and to allow 48 hours for delivery, this was on Tuesday, still not remote.
Anyone else experienced delays in this?
Sky Glass Gen2 65"
Sky Air 43" in bedroom
LG 65" TV with Puck in spare room.
Broadband with Seethelight as on new build estate that does not support Sky.
Avatar for Reevo87
Level 3 icon
This message was authored by: Reevo87 Answer
Re: Replacement remote
All resolved now, new remote is here
Sky Glass Gen2 65"
Hi @Reevo87 Hopefully you won't have the same experience that I did as I had to phone and request a new remote 3 times before I actually received one.  Admittedly this was a couple of years ago so hope they have improved the process now.
This message was authored by: Jporch316
Hi @Reevo87
are there any tracking details in your my sky app ?
Avatar for Reevo87
Level 3 icon
Sky Glass Gen2 65"
