Discussion topic: Wall mount
This message was authored by: NTRae
Wall mount
Do I need a sky wall mount for my glass air
Re: Wall mount
If you want to wall mount it, yes. It does come with a stand though.
More info on wall mounting here: https://www.sky.com/help/articles/sky-glass-wall-mounting-guide
Re: Wall mount
Hi @NTRae
Only if you want to wall mount it. It is supplied with a stand and a wall mount can be purchased from sky. Or any VESA compatible mount will work.
MikeAlanR
