Discussion topic: Wall mount
Message posted on 15 Jun 2026 04:42 PM
Wall mount
Do I need a sky wall mount for my glass air
Message posted on 15 Jun 2026 04:53 PM - last edited: 15 Jun 2026 04:53 PM
Re: Wall mount
@NTRae wrote:Do I need a sky wall mount for my glass air
If you want to wall mount it, yes. It does come with a stand though.
More info on wall mounting here: https://www.sky.com/help/articles/sky-glass-wall-mounting-guide
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Message posted on 15 Jun 2026 04:54 PM
Re: Wall mount
Hi @NTRae
Only if you want to wall mount it. It is supplied with a stand and a wall mount can be purchased from sky. Or any VESA compatible mount will work.
MikeAlanR
