7
This discussion topic has been answered Discussion topic: Wall mount
This message was authored by: BigAl29
Wall mount
Is the wall mounting on the rear ofGlass 2 a vesa fixing for a standard fit, or do I need to purchase skys own?
This message was authored by: mikealanr Answer
Re: Wall mount
Hi @BigAl29
It's VESA compatible. Just need to ensure the mount is rated for the weight of the TV.
MikeAlanR
Re: Wall mount
Hi @BigAl29
MikeAlanR
Avatar for BigAl29
Level 2 icon
Re: Wall mount
@mikealanr, thank you. I am replacing a heavy plasma so it should be ok.👍
This message was authored by: Ukbigdave
Re: You've received your Sky Glass Gen 2, what are your thoughts on how it performs?
Does gen 2 use VESA compliant faceplate for mounting. I have a Gen 1 now on an arm in a corner and hoping to switch the Gen 2 directly onto that arm, but the instructions look like its some custom effort?
@Ukbigdave
Moved your post to this thread that answers your query
The Gen2 Sky bracket is, but the rear of the Gen2 Glass set is VESA.
This message was authored by: Kane2005
Glass gen 2
Hi the first tv I brought the gen 1 came with a tv bracket however this one hasn't? its completely different to the first one I brought any help would be appreciated Thankyou
Re: Glass gen 2
Moved your post to this thread that answers your query, please read the other previous posts within this thread.
More on the Gen 2 wall mounting here;
https://www.sky.com/help/home/sky-tv/sky-tv-glass/sky-glass-faqs/articles/sky-glass-wall-mounting-gu...
Answered - Go to Answer
