Discussion topic: Wall bracket
This message was authored by: Woodybrook
Wall bracket
Can you get a wall bracket that tilts for sky glass??
This message was authored by: Padam_Padam
Re: Wall bracket
Yes. As long as you get one that can support the weight of your Glass TV. They are heavier than more traditional smart TVs so you need to be very careful. The wall it's attached to will need to be stable and strong enough too. Best to seek professional advice and get one properly installed by someone who knows what they're doing.
Avatar for Woodybrook
Level 3 icon
Re: Wall bracket
@Padam_Padam @Cheers for that👍🏻
