2
This discussion topic has been answered Discussion topic: Terrible Picture Stream Quality
This message was authored by: Parky1953
I've recently upgraded to Sky MAX Broadband and the picture on my Sky Glass 65 stream on Sky Sports is appaling.
Re: Terrible Picture Stream Quality
@Parky1953 go into the settings on the Glass TV and find the network settings where you will see the quality of the WiFi connection to the TVunless ths is showing good or excelkent you need a WiFi extender.which can come as part of tge WiFi Max package. This is quite a common issue especially if the hub was moved when fibre was installed.
Avatar for Parky1953
Thank you. It is showing POOR so is hall look at one of those 👍🏻
Answered - Go to Answer
