Discussion topic: Technical issue
This message was authored by: Bbb1999
Technical issue
On normal channels or other apps the sound and other pictures bits around the screen are showing up just not the actual picture of the film, show or channel.
on normal channels it's comes up with a message saying Technical issue or there's a technical fault please try again later
This message was authored by: AceRimmer
Re: Technical issue
Posted by a Sky employee
