This discussion topic has been answered Discussion topic: Technical fault
Message posted on 18 Jul 2025 12:15 PM
Message posted on 18 Jul 2025 04:49 PM
It seems to have corrected itself now, it had been persistent for 24 hours. Thanks for your help 😊
Message posted on 18 Jul 2025 12:35 PM
Re: Technical fault
@Waydon1- How is your glass tv connecting to your router, what speed is being received at the tv. Are you connecting over wifi or ethernet?
Open netflix on the TV, go to Get Help, run connection test.
What speed is showing here
Message posted on 18 Jul 2025 03:02 PM
Re: Technical fault
Hiya, connected via wifi, connection speed 134.97mbps
Message posted on 18 Jul 2025 03:34 PM - last edited: 18 Jul 2025 03:35 PM
Re: Technical fault
@Waydon1- Speeds are more then adequate, Is this happening when first turning on your Glass TV or during watching something?
Message posted on 18 Jul 2025 06:40 PM
Re: Technical fault
Been happening here too all day, impossible to watch the golf thought this issue would have been sorted after the last outage on Q and switching to Glass grrrr
Message posted on 18 Jul 2025 08:18 PM
Re: Technical fault
It was the golf that I wanted to watch too, really frustrating 😡
Message posted on 18 Jul 2025 09:31 PM
Re: Technical fault
Seems to be happening to a few judging by the handful of posts on the forum today
Message posted on 18 Jul 2025 09:48 PM
Re: Technical fault
@Jporch316 It happened to me this evening at 9pm when I went to watch a U&Alibi programme from my CW rail. A reboot resolved it as usual.
Message posted on 18 Jul 2025 09:52 PM
Re: Technical fault
@Fothergill1 wrote:@Jporch316 It happened to me this evening at 9pm when I went to watch a U&Alibi programme from my CW rail. A reboot resolved it as usual.
@Fothergill1 In another thread @Paul+Dray suspects its as a result of a new qs update
Message posted on 18 Jul 2025 10:43 PM
Re: Technical fault
Yeah though I've got a Stream Puck not Glass. Seemed to start yesterday when my build changed from Build: QS036.019.00P to QS036.021.01P. It seems to have resolved itself now though today. So not sure what happened.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS040.024.00P; UI Version: 3.214.2 | Sky Broadband Superfast
Message posted on 18 Jul 2025 10:46 PM
Re: Technical fault
@Jporch316 He might be right. A few days ago I was on UI 2.30.0 but I noticed earlier today that I am now of UI 2.50.0 but I don't know when the updated happened.
Message posted on 18 Jul 2025 10:52 PM
Re: Technical fault
I hadn'tnoticed the Build version has also changed @Paul+Dray but I see I have actually gone backwards. A week ago my puck was on QS036.023.00P and today I see I am on QS036.021.01P
Message posted on 18 Jul 2025 11:25 PM
Re: Technical fault
@Fothergill1 wrote:I hadn'tnoticed the Build version has also changed @Paul+Dray but I see I have actually gone backwards. A week ago my puck was on QS036.023.00P and today I see I am on QS036.021.01P
Yeah I went back a few weeks ago to a lower number build. Not sure the reasons for going backwards as I didn't have any problems.
Message posted on 15 Aug 2025 06:47 PM
Re: Technical fault
Where do you find UI number?
