Discussion topic: Sky remote not working
Message posted on 08 Apr 2025 07:16 PM
Message posted on 08 Apr 2025 07:35 PM - last edited: 08 Apr 2025 07:37 PM
Re: Sky remote not working
Press and hold 7 and 9 together for 3 seconds.
Press and hold 1 and 3 together for 3 seconds.
Wait until you see the 'Your remote is now connected' message and select Continue.
Message posted on 08 Apr 2025 07:52 PM
Still won't work the buttons light up but no red light
Message posted on 08 Apr 2025 10:00 PM
@JENNA061 wrote:Still won't work the buttons light up but no red light
Hi @JENNA061 Unlike the Sky Q remotes there is no red light on the glass/stream remote, just the numbers lighting up when you use it. Anyway to help you try to get your remote working the links below are to remote troubleshooting guides:
If the troubleshooting guides don't help you could try the following. Although this sounds a strange thing to do it has worked for me twice when my remote has stopped working. It's certainly worth a try. Hold the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.
If it is still not working I would call Sky to request a replacement.
