Discussion topic: Sky Home screen
Message posted on 04 Dec 2024 08:21 PM
Sky Home screen
Sky Glass Home screen changed a couple of weeks ago. This was an improvemnt. It has now reverted to the old home screen?
Message posted on 04 Dec 2024 09:09 PM
Re: Sky Home screen
Hi @amjam1
Changed in what way? Sky constantly move things around to promote certain content over other content.
The only thing that is pretty much static is the first few rows and everything after TV guide can vary.
MikeAlanR
Message posted on 04 Dec 2024 09:18 PM
Re: Sky Home screen
A new top level which had 3 buttons - one was apps. and another was play llists. It was useful since it reduced scrolling.
Message posted on 05 Dec 2024 07:44 AM
Re: Sky Home screen
The favourites section has been updated as well. New look, and new "refresh" feature which automatically updates the favourites bar based on the channels you watch
Message posted on 05 Dec 2024 06:35 PM
Re: Sky Home screen
I'm with you on this. The new screen was a great improvement. Getting to Apps and Playlist was so much easier.
But they have gone back to the "old" screen and if anything it's looking rather cluttered to be honest.
Quickline FTTP 500Mb/s Download and Upload.
Message posted on 05 Dec 2024 06:43 PM
Re: Sky Home screen
@amjam1 wrote:A new top level which had 3 buttons - one was apps. and another was play llists. It was useful since it reduced scrolling.
Hi
I didn't see this on my glass unit ? Are you a sky employee or ex sky employee as they may have a staff unit ?
Message posted on 05 Dec 2024 08:07 PM
Re: Sky Home screen
No. Just an ordinary old glass customer.
My daughter also had the new home screen as well.
Message posted on 05 Dec 2024 10:31 PM - last edited: 05 Dec 2024 10:38 PM
Re: Sky Home screen
@Jporch316
All customers had a new Home Screen layout for over a month on Sky glass and Sky Stream
The new layout was quick access to 3 large size tiles for TV Guide/Apps/Playlist located at the start of Home Screen
From December the Home Screen reverted back to previous as in does not have these 3 large size tiles
Message posted on 05 Dec 2024 11:34 PM
Re: Sky Home screen
I must have missed that totally 🤦🏻♀️
Message posted on 06 Dec 2024 12:56 AM
Re: Sky Home screen
@Jporch316 I now only have a stream puck but, like you, I never noticed it on the puck home screen which presumably would be the same as Glass.. It actually sound as though it would have been useful. As @amjam1 mentions in post 3 above it would certainly reduce the amount of scrolling which can't be a bad thing (all the coating is wearing off my remote).
Message posted on 06 Dec 2024 06:37 AM
Re: Sky Home screen
@Fothergill1 wrote:@Jporch316 I now only have a stream puck but, like you, I never noticed it on the puck home screen which presumably would be the same as Glass.. It actually sound as though it would have been useful. As @amjam1 mentions in post 3 above it would certainly reduce the amount of scrolling which can't be a bad thing (all the coating is wearing off my remote).
Ah .... I'm not going mad then ! I'm 100% certain I didn't see this on my glass or pucks
