4306
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by: Bodston
Re: Sky Glass Power up Issues 19-9-24
My Sky stream still will not work. It did not turn on yesterday morning and has not worked since. I have rebooted it several times with no luck.  It downloads new software, then verifies and then downloads the sofware again. The Sky logo appears on screen, then disappears. The white light on the puck remains on, but nothing else happens.
This message was authored by: Spartacus1970
Reset directions from Sky do not work unless you reset your broadband router 1st turn it off then wait for WiFi to come back on. You then need to go through the reset process as suggested by Sky it was the only way that worked for me.
This message was authored by: Brian300
About my sky glass tv
I want to know when will be fixed I can't watch tv and it making mad all this
This message was authored by: Jporch316
@Mickconms wrote:
Hi thanks for this answer. Why did it take sky so long to issue it? I found that both of my sky glass TVS were not functioning at 9 am yesterday morning. After checking the forum and only finding one comment about the issue from another customer. I searched the web and found the solution you have provided on a post from a daily newspaper within a couple of minutes. Luckily this process worked successfully for me. But I could have done with the details from sky instead of having to search for them myself.
@Mickconms
The fix was issued yesterday morning and posted on this very large thread the same time. Also most users received a text message yesterday afternoon with the link to the fix
Follow the procedure exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
My sky tv won't come on
Re: About my sky glass tv
This message was authored by: Chloe240
Have tried this. Still no luck, still stuck on a blue screen saying 'updating software' but is not doing anything.
This message was authored by: Rty
The incompetence is breahtaking
This message was authored by: Zoltron
@Bodston
The procedure for Stream is exactly the same as glass.
Unplug, leave unplugged for 60 seconds,
Hold the standby button on the underside of the puck, now connect power, do not release the standby button until either of the following happen, either you get on the front of the puck a rapidly alternating flashing red and green light or the sky logo. Eventually you will get a blue screen which starts the firmware download process.
if you persevere it will work.
you then just go through the setup process where you need to activate on Sky.com/activate
@DanJC1975 wrote:
Think I have finally got it working! Created a mobile hotspot on my phone and it then connected to my router via that and did the update in a minute or so.  Will try connecting directly in a bit when I've finished watching what I'm watching on my previous Samsung tv that I luckily still have
That is good to hear.
It does sound as though the wifi or ethernet at some stage is getting stuck with this issue for some.
Hence why we have been suggesting when seeing it for un/plugging ethernet in and out and rebooting router.
This message was authored by: andylambert1954
Sky
Puck just flashes then switches off.
Tried restarting but still no connection.
Other puck is fine.
This message was authored by: Stacy8
It is not working for all users. Some users devices are still down
This message was authored by: Emmaalfie12
Sky glass still not working
My sky glass is still down! Resetting it or turning tv off for a period of time hasn't helped!! Any other ideas? Black screen of death is getting annoying now! Especially with how much I pay a month
Locked
Answered - Go to Answer
