Discussion topic: Sky Glass 75 Inch
This message was authored by: Jaxon1975
Sky Glass 75 Inch
Hello Sky are there any chance a 75inch Sky Glass will become available? I already have a 75 Inch TV but would like sky glass TV but don't want to lose the size. Thanks in advance
Re: Sky Glass 75 Inch
@Jaxon1975  Your not contacting Sky by posting here, given there have been 2 Versions of Sky Glass both without A 75" screen id say it's unlikely to happen.
You should be aware Sky will never post publicly about any future plans
This message was authored by: Hunter2660
Just add a Stream puck to your 75" tv. Job done.
I dread to think what the weight of a 75 inch Sky Glass would be.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Minimum 4 person job 🙂
@Jaxon1975
Almost certainly not: the market for such things is limited and the cost of expanding that enclosure would be significant.
There's probably more likelihood of a 75" Sky Glass Air than a Gen2 (or Gen3 😎) Glass TV.
There are plenty of distinctly low and mid-range 75" LED LCD smart TVs out there at the moment, produced for those who believe that screen size is the most important thing in a TV. Sky could probably create a 75" Air for less than £700 which would fit into that part of the market.
It's not really a mass market size though. Most people think that 55" is plenty big enough for the average front room in the UK.
This message was authored by: Gincap
What Sky market for the UK is right for mass production. We used to manufacture 32" as the biggest selling TV size for years but that has been replaced by 39-43" these days.
55" is basically the standard size for UK living rooms especially in more modern houses or the older Wimpy homes as living rooms just can't take a bigger size, that said with wall mounting becoming more popular then 65" are growing in popularity. Beyond 65" currently is more niche and I can't see Sky going there with current numbers. Personally I'd like to see Sky improving panels for Gen3 and improving on the software performance.
This message was authored by: 2muchTV
🤣 which raw plugs will I need for an install on a plasterboard wall?
Former Sky HD+, Q and Stream customer
Now TV Sports + Entertainment + Cinema + Ultra Boost @ £31 pm (till October 2026)
2 x FTTP lines: Digi £15 pm 900/900 & Aquiss £36pm 80/20
Connected in dual WAN to XT9 mesh
65" Samsung S92C OLED TV
6 other streaming TVs
@2muchTV wrote:
🤣which raw plugs will I need for an install on a plasterboard wall?
The wall wouldn't be there long me thinks. 😁
