Discussion topic: Sky Cinema
Message posted on 05 Mar 2026 02:35 PM
Sky Cinema
I want to keep everything I have but cancel Sky Cinema.
Following an email to contact Sky, I made contact and was told to phone back in two months which I am doning.
All I want to do is cancel Sky Cinema - is that so hard?
Message posted on 05 Mar 2026 02:56 PM
Re: Sky Cinema
Hi @Barbara408 This is a customer help customer community forum so we cannot help you with your Cinema problem. You will need to call Sky to sort this out. FYI - When I cancelled F1 Sport at the end of last season I just phoned them and they cancelled it (with 31 days notice though).
Message posted on 05 Mar 2026 04:53 PM
Re: Sky Cinema
@Barbara408 wrote:I want to keep everything I have but cancel Sky Cinema.
Whether they let you cancel Sky Cinema will perhaps depend on whether you have Sky Cinema as part of a minimum term ( at a discount) or you are paying the monthly rolling cost for it. If you have it on a monthly rolling contract then you can cancel anytime giving 31 days notice, however it you have it under a minimum term contract Sky do have the right to reject the cancellation until the minimum term ends.
Message posted on 05 Mar 2026 05:27 PM
Re: Sky Cinema
Did they say "phone back in two months" because there was two months left on your contract?
