Discussion topic: Remote control broke
This message was authored by: Anna0407
Hi remote controls not working, I've only had sky glass 3 months. I've tried new batteries and it's still not working.
Many thanks,
Anna
Re: Remote control broke
Many thanks,
Anna
@Anna0407 this may sound strange but it has worked for some people hols the remote in both hands the twist the remote like you are wringing out a cloth
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Anna0407 The twisting method as suggested by @Laing1 has worked for me on a couple of occasions but if you are not so lucky you will need to contact Sky Customer Services and ask them to send you a replacement.
You can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote if the solution provided above doesn't help
@MarkGoldsmith I am waiting for clarification from @Chloe-W22 as I have been asked by her in a PM to not use this link any more 🤷‍♂️
