Discussion topic: No connection
Message posted on 01 Aug 2026 02:39 PM
No connection
Message posted on 02 Aug 2026 10:56 AM
Re: No connection
Thanks,
Message posted on 02 Aug 2026 10:59 AM
Re: No connection
Hi @Kirs To stop your Glass TV losing the network connection when it is in standby so go into the Settings > Start up & standby menu and make sure that the option for "Networked standby mode" to ON.
This resolved a similar problem for me when I first got a Glass TV so hopefully it will help with your issue.
