Discussion topic: No connection
This message was authored by: Rosemarie3
No connection
1 have sky glass, and no connection since yesterday evening around 10.15pm, it is still not working
Re: No connection
@Rosemarie3  Have you unplugged the TV for a few minutes?   Do other devices connect to your broadband router?
Are you connecting over wifi, are you able to try ethernet if your broadband service is running ok.
Avatar for Rosemarie3
Re: No connection
I have disconnected the broadband from the socket and still not working
Re: No connection
Trying to connect through WiFi
Re: No connection
@Rosemarie3  Unplugging the broadband won't help, have you tried this with the TV itself?
