Discussion topic: Issue with Sky glass connection
This message was authored by: adam8
Very often when I turn on the Sky Glass tv it says:
No WiFi Connection
Check if your router is working as normal.
i don't use WiFi with my Sky Galss tv as it is connected via Ethernet. Also there is nothing wrong with the WiFi or the router.
The problem is they've won't come off that error page unless I switch off the tv at the wall socket and then restart it after 30 seconds or so.
i wouldn't mind if this happened every now and again but it's happening every day. And this Sky Glass TV is only a few months old!!!!
This message was authored by: Jon712
Re: Issue with Sky glass connection
This is  exactly my issue
