1
This discussion topic has been answered Discussion topic: How long will it take for a replacement remote
This message was authored by: Silverfox292
How long will it take for a replacement remote to come
This message was authored by: Fothergill1 Answer
Re: How long will it take for a replacement remote
@Silverfox292 If you order one online I believe they take about 3 days.  If you have an old Sky Q remote available you can use that while you wait for a replacement.
Replacements can be ordered at the following link: Streaming TV replacement remote
