This discussion topic has been answered Discussion topic: How long will it take for a replacement remote
Message posted on 11 Jan 2024 07:48 AM
How long will it take for a replacement remote to come
Message posted on 11 Jan 2024 08:15 AM
@Silverfox292 If you order one online I believe they take about 3 days. If you have an old Sky Q remote available you can use that while you wait for a replacement.
Replacements can be ordered at the following link: Streaming TV replacement remote
