Discussion topic: Sky glass voice control not very responsive
This message was authored by: Louisew71
Have had sky glass for a  week am seriously considering sending it back. The voice control is not very responsive at all after about 5 attempts it sometimes works. The picture is buffering then going black. Is this normal or do I have a faulty tv ?
Re: Sky glass voice control not very responsive
Hi @Louisew71
What speed is your internet connection and how is your Glass connected? If possible try connecting via ethernet cable and turning off WiFi. The symptoms you have outlined suggest poor connectivity. The voice command NLP (Natural Language Processing) is processed server side (i.e. on sky's servers rather than locally on Glass) and poor connectivity could impact it's performance.
That said, having had Glass for 2 years, I find voice command using the far feild (I e saying hello sky) a lot less reliable than using the mic in the remote.
MikeAlanR
@mikealanr wrote:
Hi @Louisew71
MikeAlanR
In addition to @mikealanr suggestion, when connecting via ethernet and then disabling the wifi, it bet to restart the TV by turning it off at the plug for a couple of the minutes. I've seen on occassions where disabling the WIFI doesn't properly take affect until a restart.
Avatar for Louisew71
Thank you for your reply so will try this today.
