Discussion topic: Help - setting up sky glass
Message posted on 08 Jan 2026 07:08 AM
I ordered sky glass - I received a small square black box which came with a remote. I also received sky glass next gen 2.
sky glass won't work without the small black box connected to it- is this correct? The instructions were a QR code on a brown cardboard box which won't scan.
also I now have two remotes. Is one spare?
The qr code on a brown background is a bad idea. Neither Samsung nor Apple phone would scan it.
is the all glass tv supposed to stay connected to this small black box or should I disconnect?
thank you if anyone knows.
Message posted on 08 Jan 2026 08:54 AM - last edited: 08 Jan 2026 08:55 AM
Re: Help - setting up sky glass
Did you order Whole Home too? The small black box sounds as if it is a Puck for streaming and is in addition to the Glass TV.
Set up the TV power it on and follow the on screen instructions. If you do have a puck then the set up is very similar after connecting it to an additional TV but not the Glass
This is a Puck
Message posted on 08 Jan 2026 08:59 AM
sky glass won't work without the small black box connected to it- is this correct? The stream puck (small black box) is intended to be used on another non Sky Glass TV The instructions were a QR code on a brown cardboard box which won't scan. Simply follow the onscreen setup guide, do not connect the puck to the Glass TV.
also I now have two remotes. Is one spare? No, you need one for the TV & one for the puck when it's connected to a nion Glass TV
Message posted on 08 Jan 2026 12:28 PM
Yes I have sky glass next gen 2 with remote. And a puck with remote.
many glass did not work without the puck connecting to it via hdmi cable ...
do both remotes do the same thing?
Message posted on 08 Jan 2026 12:39 PM
@MaryF Your Sky Glass TV will work without a puck, did you go through the setup steps correctly? https://www.sky.com/help/sky-tv/sky-tv-glass/setting-up-sky-glass/articles/setting-up-sky-glass
Message posted on 08 Jan 2026 01:15 PM
MaryF
Plug the sky glass tv in to the mains unplug the pluck. And follow the setup on the tv the puck is for a normal tv the both work off the internet
