Discussion topic: Get sky glass code for firestick
Message posted on 29 Jan 2024 09:52 PM
I need the code for sky glass
Message posted on 29 Jan 2024 10:28 PM
Re: Get sky glass code for firestick
@Laney3 I'm confused as you've posted in the thread it's for a firestick, as far as I know Sky Glass doesn't provide codes for firesticks.
Message posted on 29 Jan 2024 11:08 PM
If you want to control the glass tv with a firestick remote on a Firestick 4K max 2nd gen scroll down the list of available tv manufacturers until you find sky
Message posted on 29 Jan 2024 11:29 PM
@Laney3 I'm not sure what you mean by a code as all you need to do is plug the firestick into one of the HDMI ports on the Glass TV. You will need to use an external plug socket for the power supply as there is no USB A on Glass..
Message posted on 16 Mar 2024 07:48 PM
Where's the code please
Message posted on 16 Mar 2024 09:28 PM
@Farouq1 Welcome to the forum. There is no code required for a Firestick see post 4 (the one just above your post) 👍
Message posted on 09 Mar 2026 07:28 PM
They mean a code to side load sky channels onto the fire stick with a code to bypass the monthly sky subscription fees which I think is illegal
Message posted on 09 Mar 2026 07:31 PM
@Farouq1 there talking about a code to side load sky channels on to the fire stick to bypass having to pay a monthly subscription to sky which I think is illegal
Message posted on 09 Mar 2026 07:36 PM
Yep quite right - they're using a dodgy firestick (seen them advertised on my FB feed) and have a real brass neck to come on here and ask for help whilst pushing up prices for eveyone else 😠.
Message posted on 09 Mar 2026 07:42 PM
@Suskha yep I pay £114 a month for everything with sky including netflix,sky sports, movies,tnt sports and the glass TV and some people I know are paying £50-60 per year for everything on a fire stick pre loaded , apparently you can now get sky sports on a fire stick via now TV but it's the same price as paying for sky through a dish or stream, not sure how people are getting away with paying a yearly one of cost for everything and getting away with it
Message posted on 09 Mar 2026 07:46 PM
@Acemaster18 this money is not going to any of the broadcasters either. It's theft, pure and simple.
Message posted on 09 Mar 2026 10:32 PM - last edited: 09 Mar 2026 10:33 PM
@Acemaster18 wrote:They mean a code to side load sky channels onto the fire stick with a code to bypass the monthly sky subscription fees which I think is illegal
Hi @Acemaster18 The thread you have replied to is 2 year old so is pretty irrelevant now. I do however understand what you are saying about the code but trying to access Sky in this manner is as you have said illegal and carries severe penalties. Some Sky content is available on a firestick via the NOW TV App I believe but only requires a valid subscription and not a code.
