Discussion topic: tv is losing power for few seconds
This message was authored by: joan65
my sky glass is cutting out to extent putting all lights in house out for few seconds & the wifi router also
Re: tv is losing power for few seconds
@joan65 can you expand on that? It sounds as though you're having short power cuts causing your Glass, lights etc to cut out, rather than your Glass causing the problems.
Avatar for joan65
it is like a power surge but sky has put up on tv technical problem, & when i check on sky app its saying problem with sky glass
