Discussion topic: tv is losing power for few seconds
This message was authored by: joan65
Message posted on 22 Aug 2025 09:57 PM
my sky glass is cutting out to extent putting all lights in house out for few seconds & the wifi router also
Find out more
Message posted on 22 Aug 2025 10:21 PM
Re: tv is losing power for few seconds
@joan65 can you expand on that? It sounds as though you're having short power cuts causing your Glass, lights etc to cut out, rather than your Glass causing the problems.
Message posted on 22 Aug 2025 10:30 PM
it is like a power surge but sky has put up on tv technical problem, & when i check on sky app its saying problem with sky glass
