Discussion topic: Why does my screen keep freezing and also when you press pause the programs don't catch up and freez
This message was authored by Wayne30 This message was authored by: Wayne30
Why does my screen keep freezing and also when you press pause the programs don't catch up and freezes
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: Why does my screen keep freezing and also when you press pause the programs don't catch up and f
@Wayne30One of the main reasons for freezing is the quality and speed of the Wi-Fi signal being received at the TV/puck and not that being received at the router.  This can be checked with the Netflix App (Get help > Check network) and is often much less than you might expect. The minimum speeds  recommended by Sky are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
If your speed at the TV is borderline try connecting via Ethernet cable. If this is not practical you can use powerline adapters (about £30 at Amazon). Note the Ethernet port on the Glass TV (& pucks) only supports 100mbps so don't waste money on the more expensive 1gb powerline adapters
If my post has solved your issue please mark as an "Answer"
