Discussion topic: Wall mount
This message was authored by: Mszb
Wall mount
Hi guys what is the best wall mount to get for my sky glass TV as want to put it up on the wall
Re: Wall mount
VESA mounts are compatible - just make sure it and the Rawl plugs will support the weight of the TV.
Avatar for Mszb
Re: Wall mount
Ok thank you do you know where the beat place to get 1 from please and the wall plugs
Re: Wall mount
Amazon? Argos?
I don't know as my TV isn't wall mounted.
Avatar for Mszb
Re: Wall mount
Ok thank you so much for your help so i need a vesa wall mount
